Just installed jb4 a week ago and have been fooling around between map 2 and 5. anyone know how long i should run map 5 before trying to put a little e85 in the tank? i plan on only doing about 3.5-4 gallons as that should be ~30% of the tank
Nope.First of all, BMW says 335i/xDrive needs 89 octane minimum.
Second of all, E85 is 15% ethanol,
So with being said what is the adverse effect on the engine? I presume you shouldn't fill the entire tank up with E85? If so, what happens...eventually? :dunno::dunno:Nope.
E85 is 85% ethanol and only 15% gasoline. It's octane number is up around 100, but there's little gas in it. Mixing 3 - 4 gallons into the tank would give you an EtOH percentage of somethere in the mid-20s. The octane number will be higher than a mathematical average of the base components (the extra ethanol gives a boost to the octane number of the gasoline), but various components in the fuel system may not be happy at all.
If the engine isn't designed for E85, there's no guarantee that all the seals, hoses, diaphragms, etc. in the the fuel system as compatible with the high alcohol content, so there's an unknown effect on the lifetime of different parts. The effects may not be immediately apparent (ie.: "I run E85 all the time, no problem. Oh, has anyone else had to replace their LPFP every 20,000 miles???").So with being said what is the adverse effect on the engine? I presume you shouldn't fill the entire tank up with E85? If so, what happens...eventually? :dunno::dunno:
:banghead: Yeah, you're right, I severly misread and inverted the figures!Nope.
