as asked by jim, are you having an actual problem or are you looking to do preventative maintenance?50, for anyone to be able to help there is a lot more information needed.
I assume your having a cooling problem, not a heating problem?
What have you done to try and fix it?
What are the symptoms?
How many miles?
Any past maintenance?
Jim
This is too vague to even consider where to begin to give you any suggestions or help.... any ideas on how to solve the heating problems on the 97 528i's? ...
Yeah cooling, but so the car was around 206,xxx and when ever it is idle for about 2 minutes it heats up and almost over heats if I don't turn it off. I just replaced the fan clutch thinking that my old one wasn't doing what it was supposed to and it didn't do the trick.50, for anyone to be able to help there is a lot more information needed.
How many miles?
Jim
It has enough coolant, and I just barely got the car so no cooling work yetCheck the coolant level when cold. The top of the float s/b level with the top of the opening.
Any recent cooling system work?
REALLY? That's the 1st time I've ever heard that...and it doesnt jibe with the owners manual nor any other BMW I've owned. But I confess, I've never owned a 6 cylinder e39...so I may be learning something new.The 97 don't have a float. ...
There ya go...I've learned something new today. As mentioned above...I've never owned a 6 cyl e39...so I've never seen this white "floatless" expansion tank.The float was added after build date 09/1998 or 99on the e39.
I have personally work on many e39 especially the early e39 528i. From 1996 build date to late 1998 No float on the white expansion tank
Thanks man, once I fix my heater I'll try thatThe 97 don't have a float. You have air in the coolent system. You must bleed the air out, the 97 is very finicky when it comes to bleeding the coolent system.
What works for my 97.
1. Turn key to 2nd position with the heater on low
2. Ad coolent to the coolent reservoir fill to the top.
3. Squeeze the lower radiator hose 5x
4. I'll squeeze the top radiator hose 5x
5. Open the bleed screw on top thermostat housing.
6. squeeze the bottom radiator hose 5 times
7. Start the car and let it worm up
8. Close the bleed screw and put the cap on the reservoir.
9. As soon as the temperature to the 12:00 positions open the bleed screw slowly to let the air out. Close this screw. And open the coolent bleed screw slowly.
Repeat until coolent flows freely from the t stat housing bleed screw.
Add coolent as needed only to the level line on the reservoir.
Every time you open the reservoir to add coolent you must bleed the air out of the system.
This may take 2 or 3 tests drives to get all the air out. After the 2nd bleed you don't need to open or add coolent just bleed from the thermostat housing screw.
You'll also want to raise the front end of the car by either parking on a slight incline, ramps or jacksThanks man, once I fix my heater I'll try that
Ok thanks for the info, I appreciate itYou'll also want to raise the front end of the car by either parking on a slight incline, ramps or jacks
