1 - 17 of 17 Posts
Hi!
I’m about to take my squeky blower motor out and give it some lovely drops of lubrication. I’ve heard that WD40 is not recommended for this since the smell of WD40 will occupy the car.
Anyone got a smellfree option to recommend?
I'm much better now, Dave
Regardless of smell, WD-40 shouldn't be used, because it's not a lubricant. It's a cleaner of lubricants.
It's a very very thin oil, that when applied to old gunky oils will thin them out and allow parts to be unfrozen and cleaned.
After only a short time, any WD-40 you've applied will attract dirt, and then evaporate away leaving the dirt.
For most household lubrication needs, I keep a can of "3-in-1 Oil", which is a great, inexpensive "average' multipurpose oil for use like with motor bearings.
(I'd use lithium grease for lubrication needs that are exposed to dirt, like door hinges, because it's not a liquid and doesn't attract dirt).
Nuclear engineer
+1
That’s a too narrow interpretation of liquid to exclude grease. A liquid is a fluid that conforms to the shape of its container but retains a constant volume. It is one of the four fundamental states of matter (the others being solid, gas, and plasma), and is the only state with a definite volume but no fixed shape.
Hi!
When the bearing squeaks, it's almost time to replace the motor. If you don't want to do that, you need to use a very light weight non-detergent oil, lighter than SAE-10 to re-impregnate the motor bushings. A bearing shop will be able to supply this product.
Discussion Starter #5
Thank you ALOT for a very good description!
Nuclear engineer
Are you sure, “bushings”? I doubt that, rather angle contact ball bearing sealed cartridge.
Doug. attached is a picture. If you look down the shaft, you will notice there is a collar, separate from the bushing carrier. It doesn't turn when the shaft does, so it's likely the motor design is a bushing not a ball bearing. I have not dissected the motor to really know for sure because I have better things to do with my time.....
Any specific product in mind?
Not really, but if you can get a hold of some SAE10 non-detergent oil and mineral spirits, you can mix your own. You will want to use a low odour type so it's not too smelly. Probably 9 parts oil to 1 part spirit should thin it out enough to flow into the bushing.
Just change the motor if I were you. It’s bound to fail anyways. I replaced mine 2 months ago after the bearing went. WD-40 won’t help. Now if you don’t want to change the motor you can lubricate it with white lithium grease.
I used gear oil in mine as I intended the oil to be thick so it sticks around the bearing balls longer.
Honestly too lazy to replace the motor it's been oiled about 3 years ago and hasn't made noise since (yet).
Nuclear engineer
Perhaps a better view
Discussion Starter #13
I will in a week or so. Until then I’m just looking for a quick fix.
Same Issue with my 2011 E90 now Not Squeaking 1 Year
My blower motor was squeaking badly. Tried numerous lubricants including teflon spray, silicone, wd40. The one that worked and has kept blower motor quiet now for more than a year is LPS3. Which is liquid white grease. Good luck.
1 - 17 of 17 Posts
