Hmmm, maybe then. The one thing is, with the weather being above 100 degrees lately, when the SS shuts off, the air pretty much goes with it. It heats up pretty quickly and at a long light, gets almost uncomfortable. On one long light, I did notice it started back up with my foot still on the brake....wonder if it has a time limit to be off if the AC is running.
Dave
The ASS system is extremely complex. The BMW engineers know what they are doing. These are most of the situations when the ASS will not work, or when the engine will kick back on:
Seriously, just enjoy the car and use it.
-The car is coasting (manual transmission)
-Brake vacuum reading is too low (manual transmission)
Insufficient brake pedal pressure is being applied to hold the vehicle stationary (automatic transmission)
-Stopping on a hill/downhill with a 12% or greater gradient
-If the steering angle is more then 6 degrees
-If the steering wheel is still be moved after approximately one second of coming to a stop
-The system has not yet be activated by going over a speed of 5mph for automatics, 3mph for manuals since the last engine switch off
-If the gas pedal is being pressed (engine must be at idle speed only)
-You're coming to a stop from reverse
-The driver gets out of the car
-If Hill Decent Control (HDC) is activated
-If the engine is not up to temperature
-If the carbon canister is being purged
-If the grade of the fuel is too low for the engine
-Transmission adaptation is active (automatic transmission)
-The hydraulic pressure accumulator is not yet up to pressure (automatic transmission)
-Stop-and-go traffic - system is only activated by driving over 5mph for automatics, 3mph for manuals
-Battery charge is low
-Outside temperature is colder then 37.4 F / 3 C
-Outside temperature above 95 F / 35 C and the air conditioning system is on
-Fogging of the windshield is detected by the IHKA system
-Climate control system is on but passenger compartment has not yet reached desired temperature
-ABS system was used when coming to a stop
