1 - 4 of 4 Posts
hi anyone one from vancouver .b.c know of a place for tune up that is reasonable and also i want to get f1 or huper optic tint done . and possibly exhaust installed next month if i could find a place that is trusted...
I'v called
ALL Tune in richmond they charge $300-400 for tune up ..
Henneken on Oak they charge $442 for tune up and $296 for labor and $88 for tax!! witch is well over priced !!!!
any recommendation is highly appreciated .!!!!:)
If you're prepared to go to Abby, Valley Eurotec does great work. Very professional and respected. Not sure what costs are.
Dont waste your money on a shop perscribed 'tune up'. If you want you car to run better, go to the shop and tell them exactly what to do.
Examples:
1. Change spark plugs
2. Change air filter
3. Clean MAF and throttle body
4. Replace crack case vent valves
5. Replace manifold vac hose
Total cost for all of the above should be less than 500.
If you do all 5, your car will drive like new, barring any other obvious mechanical problems.
You can go to Scan automotive in North Van to do such things. They know what they are doing, and don't charge as much as some import shops.
1 - 4 of 4 Posts
