I want to add power folding mirrors to my new 330i, which arrives next week. I've done a lot of research on this, but still can't tell if it's possible.
Questions:
Any help is most appreciated - Family Man
Questions:
- Does it require dealer re-coding to activate the folding function?
- If yes, is it a programming option available to US dealers?
- Assuming fuse 57 is present, any parts required beyond the L & R mirror bases and the switch?
- Any other advice/help? Lessons learned?
- I want standard OEM sedan power folding mirrors, not aftermarket, and not M3 style.
- I've read every related post on both the 'Fest and 'Fanatics and can't find someone who's done a ribbon cabled car.
- I've read, re-read, and dissected Terry Kennedy's excellent DIY for his '02 Touring (while very helpful, he didn't have ribbon cables).
- I've found what I believe to be the correct part numbers for the mirror bases and the switch; they appear to be US standard parts available by special order.
- I'm assuming the car will have fuse 57 since it is completely loaded, but will check before I order parts.
- I'm technically savvy, and a bit too brave with this kind of stuff; but don't want to dump $500 into parts only to find it's a no-go due to programming issues.
- 51 16 7 153 117 - Folding Heated Outside Mirror, Memory Bus, Left, Shadowline Gloss Black
- 51 16 7 153 118 - Folding Heated Outside Mirror, Memory Bus, Right, Shadowline Gloss Black
- 61 31 6 901 383 - Switch F Mirror Adjust./Fldng Bck Funct.
