I'm looking at a used 325ci, but the only drawback is it has navigation. Does anyone know if it is possible to "swap" the navigation for the cd player? Or would you just install a changer in the trunk?
You can only get the trunk changer. No way to swap out the navigation for a CD.325xi-SteelGray said:I'm looking at a used 325ci, but the only drawback is it has navigation. Does anyone know if it is possible to "swap" the navigation for the cd player? Or would you just install a changer in the trunk?
Yes they're completely different, so figure you need a whole new set (~260-280).325xi-SteelGray said:Are the clears different for the sedan versus the coupe?
Pretty much plug and play... the trim piece in the trunk is already there, and would just need to be removed so you can put the changer into the bracket and attach it to the prewire. Put the trim back, and you're done.325xi-SteelGray said:Would the changer install be easy considering the "prewiring" in the trunk?
You get the disc for your region, and 1 update free. After that you pay to get updates, or you can keep using your old ones.325xi-SteelGray said:Do you have to buy discs for the navigation? I know nothing about it. I assume you have it, yeah?
Nope... 2002 nav... I read somewhere (don't recall where now) about someone with the same system being able to use the cassette adapter just fine -- the wire (just barely) is able to make it out from behind the flip-down screen.punkman79 said:Hey Plaz!! How are you going to put in a mp3 player using the casette adapter?!?! I wanted to do the exact same thing but figured I can't on my car. wait..let me guess. you have a 2001 NAV. the 2002 NAV has the casette player behind the screen. I dont know how to set it up so it looks so fresh and so clean...DOH......all this worrying and I still have 7 more weeks until I get my car...
