1 - 4 of 4 Posts
Hello all,
in the future, I may eventually have to install a "new" engine, either from a wreck, or remanufactured.
My original engine is the M52B20, its a 1996 E39 520i sedan made in germany.
I would prefer to replace with an exact copy if needed, but I would like to keep a note of what I could replace with in case I don't find another M52B20.
All the other M52 fit directly?
All the M50 fit?
All the M54 will fit directly, no major mods?
If the time comes to replace engine, I will not be interested in getting more horsepower or anything, and I don't mind using the M52 smaller inlet manifold in an M50 for example, or in an M54.
Anyone out there has experience or an opinion about this? :dunno:
:thumbup:
Discussion Starter #2
I guess I should add to this conversation the previous information laid out here:
https://www.bimmerfest.com/forums/showpost.php?p=5915701&postcount=11
"I have installed a 3.0 into a 525i. I used the existing intake manifold, exhaust manifold, etc and it worked just fine. If you want to use the 3.0 accessories, you will have to buy a lot of extra parts like airbox, maf, engine computer, and align the DME to the key so it will start.
Here is a list of what can be done without a problem to the e39
1999-2000 323i e46 to 2001-2003 525i
2001-2005 325i e46 to 2001-2003 525i
1998-2001 Z3 2.3i e36/7 to 2001-2003 525i
2004-2005 525i to 2001-2003 525i
1999-2000 328i e46 to 1999-2000 528i
1996-1998 328i e36 to 1997-1998 528i
2001-2005 330i e46 to 2001-2003 530i
1999-2006 X5 e53 3.0i to 2001-2003 530i
2001-2002 Z3 e36/7 3.0i to 2001-2003 530i
2004-2005 530i e60 to 2001-2003 530i
2000-2003 X5 e53 4.4i to 1999-2003 540i
1999-2001 740i e38 to 1999-2003 540i
You can upgrade your engine, but you cannot easily go from single VANOS to dual VANOS, you have to stay with what you have. If you have a 2001 525i, you can upgrade to a 3.0, but you have to use all of your existing 2.5 accessories if you do not want to go with the hassle of getting your DME aligned to your key.
If you have a 528i, you cannot really upgrade unless you swap over the wiring, engine computer, transmission, transmission computer, and get the electronics aligned to your car. It is doable, but not really worth it. by Jimmys_530i"
Discussion Starter #3
I guess the main lesson so far is to try to use the closest possible to the M52B20 -> M52B25 -> M52B28.
Anyone ever installed an E34's M52 in an E39 here?
How about the M50?
1 - 4 of 4 Posts
