This is a series of pics taken during the last 3 fluid changes. Unfortunately, the 3rd fluid change was just bout as dirty as the 1st, so I'm going to keep changing it until I get some nice red fluid.
1st pic show the short Allen drive socket reaching up over the exhaust (drivers side) to pull the level check plug. Also note the very clean pan exterior. I still have a valve cover gasket leak and the pan was covered with dirt and oil, so first part of this process was taking the car to the wash rack to clean the pan before it's removal. (A carry over from working on race cars. They'd come right off the trailer and into the wash rack after a race.)
2nd pic shows the sludge that was in the bottom of the pan. Note the 4 magnets sitting in the circles at each corner of the pan. The are just small, factory, lose bar magnets that you can take out and clean.
The 3rd pic shows the poly drive bolts (screws?) used to hold the pan to the trans, and also the Allen head level check plug being removed by the short 3/8's drive Allen socket. It really helps to have Allen head sockets because many of these bolts and plugs haven't been out in many years and can be quite stubborn. While it would be possible to use an Allen key with a piece of pipe over it, the correct, short Allen sockets are available at HF for bout, $10 and allow you to use as big a breaker bar as you need, then switch to a small socket wrench to finish the job. The next time you run into a stubborn Allen, you can pat yourself on the back for being so smart you picked up a set of them cheep and being ready.
