Got an aftermarket gasket filter kit. Came with bolts, so I Figured I'd use them. Most of them torqued to spec just fine, but a couple seemed to yield early and one actually torqued off. What's the best way to fix this? Will one of those easy out bits work without destroying the housing/threads? Give up, drill out and re-thread to slightly larger bolt?
The bolt is right in a corner, which I assume is probably the worst spot. So far it's not leaking.
