101 - 120 of 169 Posts
I have also retrofit atm everything works for me included remote service but I do not see level fuel, door status (open or closed) real km etc ... do you know how to make this work?
Enviado desde mi iPhone utilizando Tapatalk
I have done that and tried with a different phone and still the same :)
Maybe there is some coding that need to be done
I have this same issue. Was your head unit destined for a BMW, or possibly a Mini without an optical drive? I flashed mine with the FA of a Mini, and then FDL coded everything else. Was considering flashing with a BMW i FA and seeing if this works, as they have Evos without an optical drive as well.
Hello
The EVO came from a X5
The “old app” works as I should
But if I remember correct it use to work
I am thinking of VO code it and see but I am a bit unsure of what car in FA to use F13? Does that work?
Ok does it also show in app when the car is running?
Mine update almost like I should if I open a door and close and lock it it updates but if I start the car and drive it doesn’t update before I have stopped the car lock it then open it and lock it again then it update?
Also nothing is showing in app when the car is running
I have same problem, it comes out in app Connected d nbt evo, they told me that it was because there was that option deactivated in bmw server, but I do not know if it is correct or not. I also have another problem and is that the connected application does not tell me status of the car (open or closed) km total, km fuel, but if you tell me the location, horn, lights lights, opens and closes .... what can I do ?
Today I connected a android phone to my car and the app worked like I should and when I disconnected that and connected my iPhone back it worked also like it should
But after a little while it stop and the X was back???
Think i found a sollution on an other forum to get the atm to work oem with your vin. If you have an nbt with a tcb module you can get the tcb module take it apart and take out the sim chip (withc contains your emeinr) then buy a used atm modul take out that sim chip and chang it with yours.
So then you have an atm module with your emeinr in it so then it everything should work
Same problem, android is ok, iphone no ok, and no status car in app android and iphone
