1 - 19 of 19 Posts
When I picked up my 330xi the dealer activated the auto door lock feature to make the locks engage a few seconds after you started to drive away.
The feature worked for the first few days but stopped working. Any idea why? Do I have to go back to the dealer to have them re-activate this feature?
thx
Did you by chance, switch ignition keys??
I think this option is programmed to indiviual keys, but I could be wrong.
Or else, yes, you will need a second visit to the dealer.
Did they program your "clown nose" also???
If not, have them do that too.
I did not have the auto-lock feature turned on, so I can't offer any other input.
I have noticed, however, on my car that the radio's auto volume level keeps changing. I set it to level 1, and it stays that way for about a week, then turns itself back up to level 3 again.
I'm sure the service dept. will say it's normal, or that they can't find anything wrong with it:thumbdwn: :)
'Fester
The same thing happen to me this week, but I did switch keys. I am switching back tomorrow and see what happens. Otherwise, I am going to stop by the dealer and have them reprogram this.
Into the dark ages
similar problem
hey..
i had the dealer program my lights to flash when locking/unlocking the doors. for some reason one day it just stopped working. but after a few restarts of the car it seemed to have 'fixed' itself and it works now. could be just a minor mix up in the s/ware code. it may just work itself out(assuming u didn't swap keys), i didn't.
If the car is unlocked with the valet key, none of the key memory settings will be applied until the vehicle is locked and unlocked again with one of the remote keys.
Just thought that someone might have unlocked the car with the valet key at some point.
doh!!!
I think BMW has some software bugs for the auto-lock feature. My wife key has auto-lock on and it seems to work ok. My key is supposed to not have it on and sometime it auto-locks and sometimes it does not. I cannot figure out a pattern either. Bugging software is my guess.
Jeff
Discussion Starter · #11 ·
I think it's a bug. The car is only 1 week old and I have not used the valet key. I can live with the lock thing but I hope I don't experience additional software related problems.
Auto locks
Never worked from the moment I got my new 3er. All of a sudden, they decided to work today. Worked about three times straight and then went back to not working. WTF? No, I haven't done a reprogram attempt with the dealer b/c it really isn't a big deal, but I was just surprised to see them work. Oh and the only thing I did differently today was open all the windows/roof to air the car out (hot) manually by putting the key in the door instead of using the remote. I just didn't feel like holding the button down to do it..call it being lazy. Anyway, strange!
Any additional thoughts? TIA.
Hmm... sounds like "general module" problems... aka the main computer (not the engine / gearbox computer!). I've had mine replaced since I've had my car. Twice. And I've only had it since March.
Ask your dealer to check you've got the right version, and re-program it if necessary to the latest software version
-The Mouth-
I had Adam at the service center program the auto lock above 5 MPH BUT...... it only works with one of my keys AND the lock has to be opened with the key only not the unlock button on the remote.Never bothered to get it working fully:rolleyes:
Banned
Hold on a minute... This is a key memory feature, so it is specific to an individual key. Unless you are claer that you want it activated for all your keys (and give them all to the Service Adviser when you take it in for the programming), it will be set up for only the key they have.
Also, due to the key memory feature the car wil configure the many programmable options according to the settings for the last key that was used to unlock the car via the keyless remote. If a different driver with a different key gets in the car and starts it up without unlocking the car, the settings will not reflect the preferences programmed for that key if they are different.
I think if you did a better controlled experiment you'd find that one of your keys activates the 5MPH locking, and the other disables it. The behavior of unlocking mechanically vs. keyless will prove to follow the description I've given above. It works flawlessly that way for me, and I don't think I have any different firmware loaded in my car than anyone else. :dunno:
-The Mouth-
I wasn't experimenting. I took the car to have the feature turned on knowing that it was key specific memory feature. I completely understand how
this feature works....while both keys were turned into him to program only one was programed.Thats all there is to it. no questions, qualms, or wonderments. I understand how it works and why one works and the other doesn't work/disables the feature. Thanks though ;)
Jeff
Mine's a bit buggy too. I have one key programed with auto-lock, the other without. When I switch between the two, the feature doesn't work/does work when it's not supposed to for the first few times I start the car with the opposite key. :dunno:
doh!!!
Man, you guys dug up a old thread, one year anniversary.:D
My keys still do not work properly:( My key autolocks sometimes and does lock the car all the time, wifes set seem to work ok. Temp setting seems to move around sometimes too.
Last time I took it into service it work fine for the service guy and I looked like a ass:confused: We need to bring it into service again in a week or so and I plan to leave if for the day so they can fix the darn thing.
1 - 19 of 19 Posts
