1 - 18 of 18 Posts
Hi I was wondering my auto roll down for my windows doesn't work... is there a way to reset it or does it have to be programmed??? Thanks
Keeping it surreal
Are you aware that you have to press the unlock button twice, and hold it down on the second press?
Das rampen abwarten
Are you referring to remote operation with the keyfob as Fast Bob refers to above; or just the autodown/up feature from switch operation inside the car?
If it is the latter, they can be reset by:
My window auto-up/down does not work
You can reset the window auto function by:
  • Turn the key to the ON position but do not start the car
  • Roll the windows all the way down, THEN roll them all the way up and HOLD the switch up for an additional 5-10 seconds.
  • Turn the key off
(excerpted from http://www.bimmerfest.com/wiki/index.php?title=BMW_E46#My_window_auto-up.2Fdown_does_not_work )
Discussion Starter · #4 ·
Hey Kimmy... yah I'm referring to the autodown/up feature from switch operation inside the car... I did try the method you suggested a couple of times and still no auto down or up... i don't know what i'm doing wrong... any other suggestions... thanks
Keeping it surreal
Hey Fast Bob if i do your method... would the auto down/up work from the inside operation... thanks
Auto-down *only* from the remote....no auto-up....
I would suggest pulling the wires off the switch contacts (probably the blade-type), re-install them, do this a few times to clean the contacts....they might just be dirty/corroded.
Sometimes you get lucky and it`s just a simple thing like that.
Regards,
Bob
Discussion Starter · #8 ·
Hey kimmy its all windows... it was working b4 but it stopped working either when then mechanic changed all the window regulators or when i got my computer for the car replaced...
Discussion Starter · #9 ·
Regards,
Bob
Hey Fast Bob sorry i'm not really familiar with the electrical stuff where exactly is what you said located... thanks
Keeping it surreal
You should have mentioned this *in your first post*....take the car back to that mechanc & explain the problem to him....
Discussion Starter · #11 ·
I will Fast Bob explain to the mechanic... thanks... but I was curious to see if if the method u had explained to me about using the keyfob to roll down the windows works cause i never did that b4 and yup it works... which i thought was pretty cool... thanks again Fast Bob
Sorry to interject but how do you make the windows go back up from the key? I can make them all roll down but not up.
- Garret
Ubergeek
- Garret
You use the metal part of the key, stick it under the lip on the window switches, and pull it up. :rofl:
BMW of North America sold cars have the roll up feature disabled for liability reasons :(.
Keeping it surreal
You gonna add that to the Wiki ? :)
- Garret
Put the key in the door lock, turn to the right and hold, windows and sunroof will all close after a short delay.
Holy Flamebait, Batman!
Any chance those of us with European delivery cars would have the auto-up feature enabled?
How would it work, just to test if we have it?
Ubergeek
No. European delivery cars still have the BMW of North America programming. The cars are 100% identical to cars delivered here.
To test, you'd hold down the lock button.
1 - 18 of 18 Posts
