Up front I'd venture that the plug connector into the seat module has come loose. That module is located underneath the outer seat side panel, and is exposed to a fair amount of indirect abuse (from heavy butts, bent knees, etc) over the years. If the panel is loose or cracked, you can probably peer behind it (carefully) to see if the module plug is out.HELLO GUYS.
My auto tilt/adjust function is not working when i put my key in the ignition as well as the head rest moving up and down, thats not working either. what could be the problem??
