Hi All
If someone can please help, this is driving me nuts. I bought diagnostic package from bmcables.com this is installed on windows 10 using there installer, I want to code the auxiliary input into stereo , I have installed all wiring and came to code it in , I have ncs expert 4.0.1 , inpa all work fine with no issues. I am following this video as only one really available. I get all the way to it says "read ecu) then I get the following error " COAPI-2041: wrong ecu coding index" I believe I have updated the daten files by following the below instructions to v41 and 50.2 with the same error when reading ecu. " To update the daten files, copy the files from SP-daten-E##\daten to the C:\NCSEXPER\E##\DATEN (where E## is whatever chassis you're updating). You will also want to copy the files from SP-daten-E##\SGDAT to C:\NCSEXPER\SGDAT (they're not separated into different chassis in NCS Expert, so you just want to copy and paste everything to that directory. Overwrite everything it asks about). The last step to fully updating the install is copying the files from SP-daten-E##\ECU to C:\EDIABAS\ECU "
I am using these profiles in ncsexpert
EXPERT MAN
Revtors's NCS Expert profile
Expertenmodus
In the video it says use expert mode when changing vehicle order I have used EXPERT MAN and Expertenmodus then I use Revtors's NCS Expert profile to code
Please someone help , all I want to do is code a aux input in , I have a E61 530D MSport
2005._a_
EXPERT MAN
Expertenmodus
2005._a_
