1 - 4 of 4 Posts
I have 2006 330 CI, should I have slight vacuum when I remove the oil cap? Very slight but there.
ROLL TIDE!
Very slight is subjective. You should notice a change in idle quality when you do that. If it doesn't have enough vacuum it could be a sign of a failing crank case vent valve (PCV). But it sounds like yours is normal.
Keeping it surreal
Lay a plastic sandwich baggie over the hole....if it just barely gets sucked in, you`re OK. If it tries to get totally sucked in, you`ve got a problem.
1 - 4 of 4 Posts
