1 - 5 of 5 Posts
I noticed this morning that the screen does not show the view out the back, instead showing a small block in the middle. The sound alerts still work. I pressed the camera line on the Menu selection, and it switched to a picture drawing of the car from above.
Did I switch something off unintentionally, or do I need to bring the car in?
Are you sure it's not blocked by something? I think it's the button you mentioned. If the camera is checked,the camera may be out.
it's because your trunk is open... found that out the first day I bought mine.
Discussion Starter #4
You are correct. I don't know how it was open, meaning nearly closed but not locked. Which is why I did not think it might be that. But then I did check it later, and when I saw it was not closed, I closed it and then the camera worked again.
1 - 5 of 5 Posts
