I've been reading this forum for a while and getting tips on repairing my 2006 325i with N52 engine and automatic that I bought from a dealer who couldn't get it running. Apparently it was jumped in reverse polarity. Was completely dead when I got it- wouldn't react to start button at all. I've replaced the battery with a white BMW 720amp; new IBS, checked all junction box fuses and engine control fuses (all are good); replaced the brake light switch; replaced starter; and replaced fuel pump as I progressively got power to each and diagnosed each as being faulty. Replaced spark plugs after fuel pump- it fired up and ran at idle for a few minutes on the old plugs on the first try after new fuel pump, but got fouled from oil I had placed in cylinders to lube them- car had sat for several years without starting. Naturally, I've changed the oil and filter prior to starting repairs. Ground strap from the engine/ coil wiring to right shock tower is good.
Engine now turns, gets fuel, occasionally will reluctantly start and fumble along at idle, then die. I have spark on #1 cylinder, less spark on #2 and cylinders 3-6 have very little to none- plugs are wet, but not showing signs of combustion. I've moved the coils from #1 and 2 to other cylinders and spark does not follow those coils.
I have very few codes from the engine module, despite the lack of spark and poor running. All I get from the engine module/ DME with my Bavarian Tech tool is CDA8- status Kombi, 1B4 (I believe this relates to the instrument cluster. The BC computer stalk does not function yet.) and CD94- outside temp/ relative time, 310. I replaced the temp sensor that mounts above the DME in the cabin filter tray and the correct outside temp is displayed on the instrument cluster, though.
What tests can I do to determine whether the DME is damaged? Why is it not outputting codes relating to ignition troubles? Is that portion damaged to the extent that it doesn't communicate? What is process for diagnosing lack of spark on this one? Thanks for your help!
