I have a 2007 BMW X5 3.0si. My car revs it self. When I clear the codes the car idles badly for about 3 seconds then the engine light comes on. I start the car again and it doesn***8217;t idle badly but every few seconds it revs up to 2000rpm and idles ok.
Codes come up with 4 oxygen sensor activateed, Both Vanos Solenoid, Low oil and air leak.
I replaced both Vanos and only showing port one as an issue as retarted cam shaft p0021 code.
Previously I had misfire on cylinder 4-6. I changed the coil pack and plugs and no misfire now.
I***8217;m thinking the DME is bad or something else which I or 3 people with diagnostic tools can***8217;t figure out.
