1 - 7 of 7 Posts
Hi
Hoping someone can help!
I changed the battery on my 2012 BMW 640d Gran Coupe.
When I put the new battery in, the car started but the Idrive wouldn’t come on, can’t go into drive or reverse, the cluster clocks don’t light up or the needle doesn’t move if I rev the car. The car basically does nothing but start up and the wipers come on but I can’t them turm off??
Can someone let me know if there is anything I can do or do I have to get a truck to bring the car to the local BMW garage.... 100 miles away!
Any help is very much appreciated!
Thank you. :)
Hi
When I put the new battery in, the car started but the Idrive wouldn't come on, can't go into drive or reverse, the cluster clocks don't light up or the needle doesn't move if I rev the car. The car basically does nothing but start up and the wipers come on but I can't them turm off??
Thank you. :)
Did you replace it with same battery? 'if you got different battery maybe you need to registered that battery, if not the same as the old one you had before
Sent from my SM-G935P using Bimmerfest mobile app
Hi
When I put the new battery in, the car started but the Idrive wouldn***8217;t come on, can***8217;t go into drive or reverse, the cluster clocks don***8217;t light up or the needle doesn***8217;t move if I rev the car. The car basically does nothing but start up and the wipers come on but I can***8217;t them turm off??
Thank you. :)
Not enough info to help you the best we can.
As djrynyc asked...did you replace the battery with the same type (AGM/wet-cell/lithium?)...and does the new battery have the same AH (amp hour) rating? And did you register the new battery (if it had the same specs as the old)...or register and recode the battery if the new battery has different specs and is a different type?
If you have UNLOCKED your cluster...you can go to the SYSTEM VOLTAGE test to see what the battery's voltage is. If you do this test with the engine NOT running...then it will show the battery's voltage...if you do it with engine running...it will show the system's voltage (alternator). If you don't know what this is...just go to youtube and type UNLOCK BMW cluster...look for the videos for BMWs that have the same type of cluster you have...or the models that are generational cousins (f06/f12/f13/f01/f10/etc)....the procedure will be the same.
If you check the battery's voltage and find that it is below 12 volts...then that will point to the battery's voltage is too low...and is probably the culprit of your odd electrical gremlins.
Hi
Thank you. :)
initialize ZGW FlexRay
1 - 7 of 7 Posts
