1 - 3 of 3 Posts
· Registered
Is there any harm in jump starting a 325 ci? I've heard there can be damage to electrical components if done wrong. I went on vaction for a week and the battery was dead. my boyfirend swears he didn't leave the lights on but the airport parking attendant says they definately were. :mad:
· Casey!
No prob in jump starting. Even if the lights weren't left on, the battery probably would have died anyhow...BMW batteries suck and don't like to sit for more than about 5 days. I've gone thru 5 batteries in 3 years, now I use a battery tender and no more problems (my car normally sits for a week in between drives).
· Registered
Not a problem. As you may know, the battery itself is in the trunk but a wire extends into the engine compartment so that you can jump start the car via the two + and - posts right behind the right shock/strut tower. The negative (-) is not always strong enough. if it does not do the trick, clip the negative clip to the bolt on top of the stuct. On one very rare occasion I actually had to go directly to the battery in the truck, but this should be rare.
Make sure the car that is doing the jumping has a battery of equal or larger size (e.g. 12v, 24v, 32v, 48v) I can't remember the size of the 325ci. Check the owners manual.
I use a Dodge Durango in the winter and have jumped a fair amount of 325 and 525s in winters past without any problem.
if you have never jumped a car, here are some safety tips to follow
(http://www.ehow.com/how_511_jump-start-car.html)
Its happened to me before, if you don't already have one you should get a AAA membership. AAA will provide free jump starts to members.
Good Luck
1 - 3 of 3 Posts
