My e60 is having a battery drain issue. Even if the car goes into sleep mode the icv and disa valve stay powered on. I've got a bunch of can errors. I'm thinking maybe the voltage regulator or ibs is causing this?
01 Safety and information module
3 errors
9402: UpFront left sensor defective
9404: Upfront parameter inconsistent
93FC: Undervoltage Kl.30 detected
**********12 Motor electronics
5 errors
281D: 281D BSD generator: signal
299B: 299B battery sensor: signal
2F9A: 2F9A ambient temperature sensor, communication
27A0: 27A0 E-Box fan: control
281C: 281C Bit serial data interface (BSD): Signal**
29 Dynamic stability control MK60 E5
1 error
5F48: Combi error: Time invalid or temperature invalid (ID 0x310, (TEMP_EX,
T_SEC_COU_REL)
40 Car access system
1 error
D904: K_CAN_Leitungsfehler
41 Antitheft alarm system
D944: K-Can Physical error
43 Micro-power module
1 error
D9C4: K-CAN bus low
44 Sliding/tilting sunroof
2 errors
DA04: Error K_CAN_LOW
A092: Error normalization SHD
45 Rain/driving lights sensor
1 error
DA44: Can-Low physik.Busfehler DA44
60 Instrument panel
2 errors
931B: TEMPERATURE SENSOR
E104: CAN LOW ERROR
62 MOST/CAN gateway (headunit/radio)
1 error
E184: CAN low
65 Centre console control panel
1 error
E244: CAN low, physical bus error
1 error
E2C4: Error CAN physical error
6D Seat module, driver, rear
1 error
E444: CAN low, physical bus error
6E Seat module, passenger, rear
1 error
E484: CAN low, physical bus error
70 Lights module
3 errors
9CBC: Short circuit error 1
E504: CAN low, physical error
E519: Alive signal from the ALC system is missing
72 Basic body module
5 errors
E584: K_CAN_KURZSCHLUSS
A418: KEIN_HALL_A_PULS_FH_BFTH
A419: KEIN_HALL_B_PULS_FH_BFTH
A448: KEIN_HALL_A_PULS_FH_FTH
A449: KEIN_HALL_B_PULS_FH_FTH
78 Heating/air-conditioning control
5 errors
E71B: Message (KCAN: outside temperature, 2CA)
9C77: Auxiliary water pump
E714: Message (KCAN: Power Management Battery Voltage, 3BE)
E704: K-Can physical bus error
A2 Satellite, B-pillar, right
1 error
95B8: OC3 error
3 errors
5 errors
1 error
T_SEC_COU_REL)
1 error
1 error
D9C4: K-CAN bus low
2 errors
1 error
60 Instrument panel
2 errors
E104: CAN LOW ERROR
1 error
E184: CAN low
1 error
1 error
1 error
1 error
70 Lights module
3 errors
5 errors
5 errors
1 error
95B8: OC3 error
