Anyone else having an issue with battery drain because of instrument cluster.
After ignition is turned off, doors closed, I hear buzzing sound from inside the engine compartment (i think it is from DISA). Also hear clicking sound every 13 or 20 seconds. This sound (both clicking and buzzing) never stops.
If I physically disconnect the instrument cluster or remove the fuse for the cluster (fuse # 13), the noise stops after 2 minutes and the battery drain stops.
Here is the kicker: in addition to my original cluster, i've already tried 2 other clusters and the problem remained.
