1 - 11 of 11 Posts
Discussion Starter · #4 ·
Yes, dealer wanted 303CAD
Other stores here in Canada (Canadian Tire and Parts Source) wanted between 240-260 CAD for the same model as the dealer , 90-92ah).
Lower model, 80ah, which would also suffice was 220-230 CAD, so I could have gone for that.
Non-AGM models were 150-180, but I never wanted to change the type. It even says on the OEM battery not to change it.
So, after tax, I ended up saving about $80 compared to dealer price.
Yogi - Just an FYI. Carly for iOS received an updated today. It specifically noted that the battery registration was "completely overhauled". If android received the same update, might be worth re-registering your battery to its full capacity.
Discussion Starter · #7 ·
Hi Sam, thanks for the info. Not sure if I should do it or just leave it as is. 90 vs 92 is a small difference , if they even added this option...
For now, I am perplexed at my other issue / thread i started. Brand new battery and discharge warnings. Mind you it has been extremely cold here, so i attribute everything to that and hope everything is good....
I would register it to the correct capacity is possible. I went through your other thread. The car might have some way of thinking the battery cant get back to 92ah. Eitherway, its only been a month, battery is still new, so its worth a try atleast.
Thanks again for the help everyone. These two threads have been priceless. And also one about Carly a while ago, that is where I first learned about Carly.
http://www.bimmerfest.com/forums/showthread.php?t=1187897
http://www.bimmerfest.com/forums/showthread.php?p=11822217
Here is the video.
https://www.youtube.com/watch?v=rSFgAejxEl0
Did you end up re-registering the battery after Carly update? Last week it had an update that said 'battery registration overhauled'. Yesterday morning it had another update that said the same thing.
You can update the app first, then turn on expert mode and connect to the adapter and it will update the adapter. Try the test again see what you get.
Discussion Starter · #10 ·
I updated the app, connected the same way I have before and I see the new interface, BUT I do not see a 92AH option under change battery type.
So I left it as is. Update the adapter??
BTW. I am sorta pissed off. I already spent $70 on the app and I just tried coding to shut off legal disclaimer and that is another 15 Euros!!!??? WHAT???
When I registered the battery, I coded the seat-belt reminder "for free". But "idrive coding" is 15 Euros? What???
I really doubt there's going to be a 92Ah setting, when there's already a 90. Most of the coded options are capacities spaced much farther apart than that. 2Ah is not going to make any difference to the way the car systems operate. Just leave it.
Re-registering will tell the car that you just replaced the battery again. For what it's worth, the car logs every time, and the odometer reading when it was done. On E90s it appeared that there was only 4 or 5 data slots to remember registrations on the lifetime of the car. I'm not sure what happens with you do it the N+1 time - never needed to know.
When I did this stuff on my E90, there were only 4-5 capacities with the lowest being 60 or 70 Ah. Some googling would probably reveal answers for the F10. There's only a couple of options to select, and the options are a function of the car, not the coding software.
The IMO TL;DR - if you took out a 90Ah AGM and installed a "92"Ah AGM, do the registration and forget about trying to code.
1 series example taken from http://www.1addicts.com/forums/showthread.php?t=1338304
"B" represents wet-cell, while "A" represents AGM in the VO.
E B046 BATT_46AH //46 Ah-Batterie
E B055 BATT_55AH //55 Ah-Batterie
E B070 BATT_70AH //70 Ah-Batterie
E B080 BATT_80AH //80 Ah-Batterie
E B090 BATT_90AH //90 Ah-Batterie
E A070 BATT_AGM_70AH //70 Ah-AGM Batterie
E A080 BATT_AGM_80AH //80 Ah-AGM Batterie
E A090 BATT_AGM_90AH //90 Ah-AGM Batterie
E60 5 series example from https://5series.net/forums/diy-do-yourself-14/coding-registering-new-battery-114909/ :
KLASSE_BATTERIE BATTERY TYPE
wert_00 value 00
80ah 80 ampere-hours
90ah 90 ampere-hours
110ah 110 ampere-hours
70ah 70 ampere-hours
55ah 55 ampere-hours
46ah 46 ampere-hours
70ah_agm 70 ampere-hours (agm)
90ah_agm 90 ampere-hours (agm)
60ah_agm 60 ampere-hours (agm)
80ah_agm 80 ampere-hours (agm)
Possible F10 example from http://www.bimmerfest.com/forums/showthread.php?t=837979 :
AGM: 70, 80, 90, 105
Acid: 70, 80, 90
1 - 11 of 11 Posts
