1 - 8 of 8 Posts
I ran into a post somewhere on the forums regarding this useful PDF from BAVAUTO:
https://www.bavauto.com/newsletter/2008_n108_newsletter.pdf
It lists the maintenance schedule for most if not all BMW/Minis.
I'll sum up the E39 schedule:
Engine Oil/Filter: 7k synthetic / 3k dino juice (I usually change every 5k even w/ synthetic)
MTF: 50k/2yr whichever comes first
ATF: 50k/2yr whichever comes first
DIFF FLUID: 50k/2yr whichever comes first
P/S Fluid: 50k/2yr whichever comes first
Flush Brake Fluid: 1yr
Flush Coolant: 3yr
Belts: 60k/4yr whichever comes first
Coolant Hoses: 60k/4yr whichever comes first
Cabin Microfilter: 1yr
Engine Air Filter: 15k/1yr whichever comes first
Fuel Filter: 1-2yr depending on the amount of ethanol in your fuel
Spark Plugs: 60k
Spark Plug Wires/Boots: 60k/4yr whichever comes first
O2 Sensors: 100k
Water Pump: 60-80k (indicates typical mileage of failures)
Inspect Brakes, Front & Rear Axle Boots, Driveshaft Flex Disc & Engine/Tranny Mounts, and Steering, Suspension Linkages & Joints: 30k/1yr whichever comes first
Charcoal Canister: 100k
Discussion Starter · #2 ·
Here's some stuff that I don't typically do:
Flush Coolant: 3yr (gets flushed whenever radiator is changed)
Belts: 60k/4yr whichever comes first (my mechanic will usually do a visual inspection of cracks on the belts and replace when necessary)
Coolant Hoses: 60k/4yr whichever comes first (again mechanic inspects this, and usually is replaced when the rad or h2o pump is replaced)
Cabin Microfilter: 1yr (I think this is done every tune-up)
Engine Air Filter: 15k/1yr whichever comes first (again, done during the tune-up)
Fuel Filter: 1-2yr depending on the amount of ethanol in your fuel (again, done during the tune-up)
Spark Plugs: 60k (tune-up)
Spark Plug Wires/Boots: 60k/4yr whichever comes first (never)
O2 Sensors: 100k (only when SES light is on)
Water Pump: 60-80k (indicates typical mileage of failures) - (my 98 540 is still running the original pump at 100k, i think...)
Inspect Brakes, Front & Rear Axle Boots, Driveshaft Flex Disc & Engine/Tranny Mounts, and Steering, Suspension Linkages & Joints: 30k/1yr whichever comes first (my mechanic always checks these things out every 5k when I get an oil change)
Charcoal Canister: 100k (never?)
Any opinions? What do you guys typically follow?
Discussion Starter · #5 ·
I've seen it before on my 92 525i. It was right by the driver's side headlight. I think it has something to do w/ fuel?
Stimulus Package
Bavauto Schedule
I made the post it is available at the BA site under Fast Times, that is their free newsletter in the Winter 2008 issue.
I'm otay. You are not.
They usually slip it in with their mags and newsletters. Very good suggestive selling tool.
:typing: Let's see, got my cf emblems, my new air gauge, my $25.00 window wipes, my cage for my hairy-ass golden retriever that I always take in the car with me... only a few more bucks and I get free shipping. Hmmmm..... got it! I don't remember ever changing my charcoal canister. I'm getting me one of them! :rolleyes:
1 - 8 of 8 Posts
