2008 E60 / n52 / 528xi - 62k miles
I discovered that my serpentine belt is becoming misaligned. this seems to be a common problem. It seems that the tensioner wears and causes the issue.
I have done some research on the topic including this forum and found so many differing results.
I intend to replace the idler/tensioner/belt.
For some reason the idler is not often mentioned as a replacement, and torque specs are difficult to find, so here's what I have:
I need -
t60 torx to de-tension the belt
e14 socket to remove the tensioner bolt
a new AL bolt
Tensioner torque= 25nm / 18.5 ft lb + 90degrees
idler bolt torque= 40 nm = 29ft lb
I got the entire kit from AMZN :thumbup:
Do I have the correct parameters??
I need -
a new AL bolt
