I have a 2002 525i and I just put my new 20in rims on and I really want to lower the front about an inch. Can someone give me some advice? I don't want to screw up the flawless ride so no cheap bull****.
"Screw up the flawless ride"? You just put 20's in there, that basically just degraded your flawless ride. Lowering it will degrade the flawless ride further. But if you do want to lower an inch look into HR sport springs or Vogtland. If you want adjustable height, look at coilovers.I have a 2002 525i and I just put my new 20in rims on and I really want to lower the front about an inch. Can someone give me some advice? I don't want to screw up the flawless ride so no cheap bull****.
+1."Screw up the flawless ride"? You just put 20's in there, that basically just degraded your flawless ride. Lowering it will degrade the flawless ride further. But if you do want to lower an inch look into HR sport springs or Vogtland. If you want adjustable height, look at coilovers.
Now there's a line of TOTAL BS. The ones that claim you sacrifice nothing in ride quality when slamming your car clearly know nothing about suspensions or feel nothing. You won't need a calibrated butt meter to tell the difference. The bottom line is personal taste. If you want the look or the performance, ride quality will have to give. Whether the amount of tradeoff is acceptable is a personal decision. Our feedback was based on your statement that you "don't want to screw up the flawless ride". Well, you have already tinkered with it. The 20"s may still give an acceptable ride, depending on your butt meter. That decision is yours. But every change you make will detract further from that "flawless ride". Whether you believe us or not is your call.SO MUCH WRONG INFO IN THIS THREAD!
There are plenty of ways to lower a car without sucrafising ride quality.
While I totally agree, for someone just starting out, and having a limited budget, it might be hard to get decent coil-overs like the ones you are talking about.SO MUCH WRONG INFO IN THIS THREAD!
There are plenty of ways to lower a car without sacrificing ride quality.
Most of the people on the forums talk either out of their ass or from what they have read online.
There are coil-overs out there that don't cost a fortune and that will ride infinitely better than stock OEM suspension.
How many different coilovers have you had on your E39?Now there's a line of TOTAL BS. The ones that claim you sacrifice nothing in ride quality when slamming your car clearly know nothing about suspensions or feel nothing. You won't need a calibrated butt meter to tell the difference. The bottom line is personal taste. If you want the look or the performance, ride quality will have to give. Whether the amount of tradeoff is acceptable is a personal decision. Our feedback was based on your statement that you "don't want to screw up the flawless ride". Well, you have already tinkered with it. The 20"s may still give an acceptable ride, depending on your butt meter. That decision is yours. But every change you make will detract further from that "flawless ride". Whether you believe us or not is your call.
Jason, you know I have a lot of respect for you, but you're wrong with this one.While I totally agree, for someone just starting out, and having a limited budget, it might be hard to get decent coil-overs like the ones you are talking about.
Unfortunately, I do not know of any coil-over that rides as well as Oem AND cost under $1k.
The only coil-overs I know of that can come close would be the KW's, or TC Klines, maybe the Bilstein Pss9's/10's...
However, those are getting towards $1500-$2000...(
I have heard a lot about the BC Racing coil-overs, however I do not think there is any long term use experience.
Plus, they are made in Taiwan, which makes me a little leary...
Which coil-overs did you have in mind?
Also note that when you lower the car, the spring rates need to be higher to compensate for the less travel in the suspension, hence, a more stiff ride, unless you adjustable rebound AND compression to help...
Jason
LOL!How many different coilovers have you had on your E39?
BC, PBM, Fortune auto ($1100) are all <$1000 coils and they ride amazing. Stock E39 has 7" to go up in the front and 10" in the rear before its limited by front fender rail and rear upper control arms hitting frame rail...ask me how I know. Do you really think stock suspension has this much travel?
All you need is ~2" which means that with proper valving and soft spring rates (below 6K) you wont be sacrificing any ride quality. I have had 5 different coil-overs on my car and I have ridden in E39's with probably all of the available coil-overs for our cars. I personally believe that I have somewhat solid ground to be able to talk about this.
BTW, high price coil-overs don't ride the best and in fact PSS9 were my least favorite comfort wise coils I ever ridden on in E39.
None. But having driven or ridden in many cars with many different original and aftermarket suspensions, there is ALWAYS a DIFFERENCE in ride quality or handling when changing the suspension components. Simply replacing old with new will make a noticeable difference. In fact, any e39 with 100K+ will feel better with new Monroes than with worn OEM struts/shocks. But that doesn't make Monroes a better component. Suspensions (or the ride and handling resulting from them), much like beauty, are in the eye of the beholder. While you may feel your coilovers improve your ride quality AND handling, others might disagree. While you can quantitatively measure handling performance changes, ride quality is and always will be subjective. I am sure that you feel your changes have greatly improved appearance and performance with no degradation (or maybe improvements) in ride quality. That's great. But suspension solutions are not a one size fits all. If someone who thinks a 10 year old e39 has "flawless ride quality", he needs to drive one where the entire suspension has been refreshed or get his butt meter recalibrated.How many different coilovers have you had on your E39?
Welcome to the e39 forum.I have a 2002 525i and I just put my new 20in rims on and I really want to lower the front about an inch. Can someone give me some advice? I don't want to screw up the flawless ride so no cheap bull****.
