1 - 6 of 6 Posts
The trim on my car looks like crap. I am not at all sure how this happened to be honest. I know the dealer waxed the car before I picked it up, but I have only ever used Zaino on it. The car is almost a year old.
I have tried EVERYTHING to get the white smears off the trim: Peanut butter, peanut oil (with a toothbrush), Maguier's, Mother's Back to Black, you name it, I have tried it. Same old story. Looks pretty good until the next wash then back to the same greyish crappy condition.
My next step to try rubbing alcohol and/or acetone in the hopes that it is Z1 engrained in the trim. If this doesn't work, I am seriously thinking about replacing the trim. Any ideas on how hard (and expensive) that would be to do?
ARGGG!!!
-david
Trim challenged in MPLS
into things retro
just found this out . . .
yesterday, but Marco says Autoglym's Rubber Cleaner Plus will remove wax from plastic. Roadsterwench bought some and is going to try it where she has some wax on plastic trim. :)
1st step - Meguiar's #39: Squirt it unto a terry cloth and rub your trim with heavy elbow grease. This might require two or more applications. Finish with a clean, damp terry cloth.
2nd step - Meguiar's Trim Detailer: Apply with foam app or terry cloth the same way you would with regular dressing, except use a little more pressure. Wait 15 minutes and then buff the excess out.
I've fixed some pretty terrible trim with these two products....including stuff that wouldn't budge with IPA, peanut oil & EFHI.
If you ever switch from Zaino to some other wax that stains trim, all you'll need is MTD to remove the stains, provided you use it right after you're finished waxing.
Try using simply green. Look in an auto parts store. They sell it but it is not the liquid it is a sponge that you wet and then use to rub the area. This was recommended to me from the people at Mothers auto wax. It worked for me.
1 - 6 of 6 Posts
