Steering wheel buttons will work with any IR remote capable head, but you need to use a PAC or Lightning Audio adapter. I've looked at the instructions, and it requires wiring the unit into the output of the steering column, then learining the head's remote control to it, sorta like a universal remote that you'd use for home.
IMO, any aftermarket head is gonna look out of place, since it'll have a narrower face, and have to sit off to the side because of the dash opening. I recall someone mentioning having issues finding an antenna adapter, and there is the issue of taking the outs from the head and making it compatible with the stock amp/speakers, if that's what you're doing (the stock amp needs a 11v differential input).
