1 - 6 of 6 Posts
I recently bid on a part in E-Bay that is supposedly an original Bluethooth ULF module. Now that I won it I find that it doesn't have the same plugs my factory wiring harness has in my 2003 330i. Can anyone tell me for sure if part #84 11 6 938 764 is a Bluetooth module?
Many Thanks!
Many Thanks!
Here's a list of BMW BT TCUs/ULFs (courtesy of www.bimmernav.com):
Available part numbers of the Bluetooth ULF (Bluetooth Brain) from BMW
84 21 6 934 552 end of life 06/03 1st generation
84 21 6 938 610 end of life 10/03 2nd generation
84 21 6 934 961 end of life 03/04 3rd generation
84 21 6 950 089 end of life 06/04 4th generation
84 21 6 945 387 end of life 01/05 5th generation
84 10 6 955 522 end of life 10/05 6th generation
84 10 6 969 268 end of life 04/06 7th generation
84 21 6 958 358 end of life 05/06 8th generation
84 10 6 987 546 current production 9th generation
Hope this helps...JL
I've seen that part before .... its made by Motorola, the folks that make the Assist TCU with integrated bluetooth. The thing is, this part has a manufacture date of 9.2003 give or take, which is too early for BT/Assist. BMW didn't introduce that until 9.2004. Therefore, I would say this unit is one of the Assist only TCUs that floated across the 2004 model range ....
You can find it here on RealOEM
http://www.realoem.com/bmw/showparts.do?model=BL93&mospid=47714&btnr=84_0528&hg=84&fg=10
Long story ... but BMW were going to release Assist/BT in the 2004 model range, but due to issues, delayed the rollout until the 2005 model range (9.2004). So the 2004 TCUs were only ever able to work with Assist.
Discussion Starter · #5 ·
Thanks!! I figured it was probably a BT unit as advertised but something out of the ordinary. Your explanation make perfect sense. Thanks for solving my mystery.
Well actually, its bad news because I think that the unit is an Assist TCU only unit. There is no bluetooth capability, so you might want to contact the seller and ask him to explain ....
1 - 6 of 6 Posts
