thelookingglass said:Hi folks. Now I know you can scroll through your phonebook from the steering wheel, but is it possible to dial a number that's not in the phonebook?
Terry Kennedy said:If you have ULF bluetooth (pre-MY 2004), you have voice recognition in the ULF. One function is voice dialing by number. If you have Assist Bluetooth, you can add a SES module which provides the same function.
dmel said:Can you be more specific... I have a 2005 330xi manufactured in Dec 2004. I have NAV and Assist. Two buttons on the steering wheel: R/T and the talk/hangup button. I tried holding the talk/hangup button in for a while, but I never got a beep.
I guess the SES module applies to me? Can you explain it or provide a link so I can RTFM?
THanks!
KrisL said:Only if you have the voice module installed:
You can hold the steering wheel button in until you hear the beep. Then say 'dial number'
"What number?"
'411'
"4 - 1 - 1, continue?"
'Dial'
"Dialing..."
If you have NAV, you can also dial using the nav system (menu > telephone).
sunnykk said:Does that mean, tough luck on the blue tooth.
