There is currently a class action suit that was filed against Verizon, with regard to the V710, for false advertising. Verizon had Motorola disable the OPP & OBEX profiles on this phone to force users to transfer ringtones, pictures, etc, by using their pay per play services "Get it Now", and "Pix Service". Even if you get the V710 to pair with your X,
the phonebook will NOT transfer, because this requires the OPP (Object Push Profile) to do this, which has been disabled.
I went round and round with Verizon & Motorola regarding this, and finally returned the V710, closed my account at Verizon, and ported out to Cingular, buying the Motorola V551. The V551 works flawlessly with my '05 X5. The Razr V3 also works as advertised.
If you want more info on the crippled V710, go to
http://www.v710.org
Terry Kennedy said:
I had that even with the original V710 software. Note how vatkens says "This software makes the handset compatible with the BMW Assist Bluetooth system." No mention of the older ULF system. I'm about to cancel my V710 and Verizon service and go with Cingular - I tested a friend's RAZR V3 in my car and it worked perfectly.
