1 - 1 of 1 Posts
Hey guys so I bought a 2008 bmw 135i and I suspect a leaking injector, the car will misfire on cold start for about 10min until I turn it off and turn it back on agian then it works fine the whole day, I assume because the gas in the cylinder needs to be burnt out and when the car is off the injector stays open... I also noticed in 6th gear at full throttle I get the half yellow engine light come up I also assume it might be because of this injector,
my question is how do I figure out which injector is causing me problems without a code reader,
is it possible for limp mode to go on, on a 6th gear full throttle pull because of the injector
1 - 1 of 1 Posts
