1 - 2 of 2 Posts
i have been fixing issues on a recently purchased
bmw 760li 2003 preface-lift model
i have been looking through the engine readings with inpa on master and slave banks .
i was under the impression certain sensor readings were provided to the master dme and it in turn provided them to the slave dme.
now heres my issue ,on the master dme coolant temp is reading correctly
but on the slave dme it shows coolant output temp sensor reading with a ! is their a separate sensor for this reading or is this normal as i cannot get any info on it and as my facelift 760 is apart i cant check it on that .so i would be grateful for some help or if anyone can check their readings with inpa to be sure
Which option did you use for engine? I tried all 4 n73 options from INPA but no one worked to me.
1 - 2 of 2 Posts
