hi my 2 gear is gone so i need to opgrade.
i have a getrag gearbox in now but i want a 328i zf (310z or 320z? ).
but do the clutch slave cylinder fit on the zf ?.
and is the crossmember the same?.
and is the bolts that holds the gearbox to the engine the same ?.
and do the cluch fit ?.
i now i need to opgrade the drive shaft front half, but if i take the drive shaft apart do i need to re ballance it ?.
and is the shifter the same ?.
is there more ?? :dunno:
pls help if you can
pls help if you can
