1 - 14 of 14 Posts
I had my ses light on for about a month or so and the steering wheel motor would make noise while I was driving as if it were moving up and down, but it wasn’t moving. It eventually stopped doing it after a month or so but ses came back this morning and it started doing it again?? Anyone have any ideas what it could be?
Doing what? How could it makes noise when it is not moving? Are you saying it tries to move by itself?
Yes the wheel tries to move by itself but isn’t actually moving
Oh OK. Never heard of this problem until now.
But, if I were you I would look into the steering stalker mechanism, it sounds like you have a short that activate power to the steering adjustment.
I would disconnect the battery and start taking it apart.
Discussion Starter #5
Ok I’ll start messing with it tomorrow, it’s not a huge issue it’s just more annoying than anything
Does the steering wheel adjustment work when you try manually?
This might be a problem with low system voltage, but my bet is on an ignition switch problem.
Discussion Starter #7
Yes it works fine all around besides this problem, when I press the lever forward it stops the noise for about 20 seconds then comes back on
Wingnut
just fyi, the CEL and the steering column adjust motor are unrelated issues. read or get the codes read.
Just call me 777.
It could be a noise that you think is coming from the steering column but it isn't. Get the code checked.
Discussion Starter #13
I just read the codes and have a p0455: evap emissions system leak. I know one of the bolts on the flange right after the o2 sensors is loose but I don’t think that’s causing the code considering it’s past the oxygen sensors
Wingnut
evap code and any 02 faults arent related either. p0455 is a large evap system leak. check your gas cap.
1 - 14 of 14 Posts
