21 - 37 of 37 Posts
The E39’s production ran from 1996 to 2003 so how did the 95’s and 04’s get into the E39 production?
The US didn’t get the 2016’s.
(edit, fixed my typo)
The E39’s production ran from 2016 to 2003 so how did the 95’s and 04’s get into the E39 production?
Umm, I think you typo'd but good point. Because of the OBD-II mandate the E39 was delayed here in the states for a year.
Posted through Tapatalk downloaded to my neural implant
540, I will be searching for your sway bar set up. Mine is a measly 528 but I need IE or Eibach sways, badly for my taste. I have IE sways on my e30, the 46 is fine with B6’s. The 39 needs moar support laterally for me but the Buick ride kind of confounds me. Nice to hit potholes and not feel them, not nice to be wary of off ramps that say “25mph” and feel all that sway. Hard to get used to big car after a lifetime 3.er person.
Front bar is different....so you have to find the 6 cylinder version. For the rear they are the same...you could even use an M5 out back, they are cheap used. Consider installing M5 rear traction rods, those will also tighten up the rear subframe to the chassis.
owns 2001 BMW 540 M-Sport
  • Like
Reactions: JimLev
When you’re in the market for a new or used BMW, or any other car for that matter, you likely do some research before making your purchase. From my personal car buying experience, I research everything from trim packages to drivetrain options, but most importantly I want to know that what I’m buying isn’t going to drive me to the poor house in repairs. That is why I decided to see which is the most reliable BMW available.
For this search, we’re leaving out the options that you’ll find on the floor of your local dealer showroom. We’re going to look at a BMW from the past that has stood the test of time and is still running around on the streets. This model was sold by the thousands and have plenty of miles, and some multiple owners, to show that they were built with quality to last for years. Here is what we feel is the most reliable BMW, the E39.
BMW 5 Series (E39)
A few weeks ago, we ran a story on What is The Best Used BMW to Buy and received feedback from forum members that we left a favorite off the list. The ’95-’04 BMW 5 series Sedan (E39) was highly praised by quite a few in our comments, so we did some more research and found that this vehicle has quite the following and for good reason. For starters, it’s a 5 Series so you’ll appreciate the roomy interior and creature comforts that you’d come to expect from an executive car produced by BMWs. As an executive sedan, the E39 generation was and is still considered to be the best in its class. Let’s be real though; roominess and comfort don’t have anything to do with reliability and that’s what we’re here to discuss.
Available with different drivetrain packages, you’ve got some terrific variants for one of the most reliable BMW model options. Depending on the year, the E39 530i was available with different inline-six powerplants, the most popular being the naturally aspirated 3.0L M54 engine that cranked out an impressive 228 hp. When mated to either manual or automatic transmissions (both 5-speed), you’ve got a car that will surprise you with its performance while still having a reliable BMW engine.
If you crave more performance than a straight-six engine can provide, the E39 540i might be more to your liking. This model came with BMWs naturally aspirated M62 4.4L V-8 engine which, in its most powerful year, cranked out just under 300 hp and 325 ft.-lbs of torque. Putting the power to the ground as handled through the Getrag 420g 6-speed manual transmission or the alternative ZF 5HP24 or ZF 5HP30 5-speed automatic transmissions. Both offering solid performance with no stand-out flaws when maintained properly
The most powerful of the E39 family would be the BMW M5 that had the S62 high-performance variant of the M62 engine. Considered to be a V-8 Super Sedan, the M5 could reach speeds of 60 MPH in under 5-seconds because of the power produced by the 4.9L naturally aspirated V-8 engine. To keep this one of the most reliable BMW engines, engineers designed it with a dry-sump lubrication system and higher-capacity water pump to protect and minimize wear. The six-speed Getrag 420G transmission easily handles the near 400hp produced by the S62 engine, to deliver adrenaline pumping performance, while still allowing you to feel confident that you don’t have to do F-1 engine maintenance to keep it living for the long term.
Searching for a most reliable anything means that you need to look for the flaws or problem areas, and with the E39 that was minimal. In many autos you’ll find that engines and transmissions are what people find as the weak points, but that isn’t the case here. What we were able to dig up for engine issues was fairly minimal. Owners commonly found the engines to run rough, which isn’t serious but a great annoyance. A common fix for this is performing maintenance to the Idle Control Valve (ICV). This doesn’t mean replacing it, but simply cleaning and checking the proper performance to ensure it’s opening and closing as it should.
As for the chassis, we suggest inspecting the suspension bushings, which in my opinion would be a standard maintenance item on a nearly 20-year-old car, at its latest production date.
Of course, you may find some electrical gremlins when dealing with the interior of the vehicle, but again that is expected for a vehicle of its age. The main thing is that when considering the purchase of an E39, if the vehicle has been maintained properly you are making a solid investment that likely won’t nickel and dime you to death in repairs after you buy it.
Thank you to the forum members who shared their opinions on a great used BMW to purchase, which we found out to be one of the most reliable BMW model options. If you have any suggestions or input, feel free to drop a comment below.
Just bought my first E39 about a week ago. Buddy and I drove it back nearly 1500 miles without a single issue. Have the M-Sport and for its size and weight it is an incredibly capable car when on twisty roads. I came from an E36 and while it's obviously not as nimble, it is definitely much more comfortable on the highways.
Welcome to the forum.
So if it’s an M-Sport it must be a 2003.
How many miles on it?
Hey Jim, thanks. This is NotAnM5...Wanted to change names but the mod told me it'd be easier to just make a new account haha.
And my mistake, it's not an M-Sport, just a sports package with the M-Sport Suspension, M steering wheel, and M shift knob. I was looking for the 2003 proper M-Sports, but they were a little out of my budget.
The car I picked up is a 2000 and had 70,000 miles on it when I bought it, and after the road trip back it's at around 71,600. The previous owner had recently changed the oil, but I think I might change it again after the long road trip since it's better to be safe than sorry with these cars!
Gonna post some pics up of it shortly.
OK, a 2000 540 sport. 6 speed or auto?
Add that to your profile so next time you post a question about your car that info will automatically show up.
Rule of thumb is, don't buy older BMW'S if you can't DIY or don't have DEEP pockets.
Goes for all markets, imports will be even more expensive.
I do ALL of the work myself, E39 is my toy.
The amount of work, a 20+ year old, mostly neglected, car needs is huge.
Most suffer from CCV and Vanos issues, oil pan, oil filter housing and head cover gasket leaks. Expensive jobs at services.
Few mechanics that are still good with the.
E38, 39 46 53, all shared engines.
But, once fixed, they put a smile on your face every time you drive or look at them.
And they always make you look back one more time and say, "Damn, it looks good! "
Sent from my SM-G986B using Tapatalk
Definitely, as a new bimmer, you'll get to learn to live with it.
Those you listed are the most common and known sources of oil leaks.
But there are the mysterious tiny leaks -nothing that require topping off with some magic oil-. They are the worst.
Actually, I make it a hobby chasing them. My latest newfound source of oil leak on M62TU V8 engine : the connector to the oil separator on the breathing oil pipe under the intake manifold. So, I am replacing the whole pipe...then on to chasing the next leak.!!
I've been noticing two leaks when I go out for a small drive around the neighborhood and then park the car in my garage. The liquid seems clear and odorless, but not sure exactly what it is coming from. Drops around from the center of the car, around in the middle of the driver and passenger seat.
^-this.
You have drain tubes on each side of the tranny for the condensation to drain out of the cabin AC/Heater box.
If you don’t run the AC there won’t be any water dripping.
21 - 37 of 37 Posts
