1 - 1 of 1 Posts
Quality
Reviewing the latest installment of Bluetooth w/ Voice Command and SOS Assist on my 2001 330i with Navigation.
The kit is ONLY comprised of
Parrot CK3000 also sold as the Eclipse BT-E600 Bluetooth kit and the Connects2 CTPPAR007.
With the retrofit Navigation harness you can also use the CTPPAR008 and have the connections directly off the BM53 Radio Receiver in the trunk but running the mic wire to the front may be tricky.
If your E46 3 Series came with Navigation from the factory then the CTPPAR008 is your only option.
Those who retrofitted the Navigation, like me, will have both options of using either the CTPPAR007 or CTPPAR008 since the Navigation Retrofit harness allows for the 17 pin type CTPPAR007.
Special thanks to SolidJake for having great timing! :thumbup:
1 - 1 of 1 Posts
