Hi!
I'm experiencing some problems with my 2005 e61 535d.
I'm not able to start the car (it cranks) and i get an fuel pump fault error message.
When i turn the car on i can hear the buzzing off the pump and splashing from the tank if i would guess. According to the cluster i should have enough diesel (1/4 of the tank) so that shouldn't be the problem.
The message goes away after a while when the pump stops priming
At first i thought that it would be either my battery or DDE relay so i replaced them, but it didn't help.
I read the fault codes and only fault code for the pump was current too low (6294).
Any suggestions what it would be the problem in my case
