Number | X-pin, colour | Description |
X300 | 12-pin, black | Component connector Park distance control (PDC) |
X18013 | 18-pin, natural | Component connector Park distance control (PDC) |
X18362 | 18-pin, black | Component connector Park distance control (PDC) |
Pin | Type | Description /Signal type | Connection /Measuring notes |
1 | E | Supply, terminal 30G | Fuse F69 |
2 | E/A | Signal, CAN-bus | CAN-bus connector |
3 | Not used | ||
4 | Not used | ||
5 | Not used | ||
6 | M | Ground | Ground point |
7 | Not used | ||
8 | E/A | Signal, CAN-bus | CAN-bus connector |
9 | Not used | ||
10 | Not used | ||
11 | Not used | ||
12 | Not used |
1 | M | Ground, ultrasonic sensor | Ultrasonic sensor, rear right |
2 | M | Ground, ultrasonic sensor | Ultrasonic sensor, rear left |
3 | Not used | ||
4 | Not used | ||
5 | A | Supply, ultrasonic sensor | Ultrasonic sensor, rear centre right |
6 | A | Supply, ultrasonic sensor | Ultrasonic sensor, rear centre left |
7 | A | Supply, ultrasonic sensor | Ultrasonic sensor, rear right |
8 | A | Supply, ultrasonic sensor | Ultrasonic sensor, rear left |
9 | Not used | ||
10 | M | Ground, ultrasonic sensor | Ultrasonic sensor, rear centre right |
11 | M | Ground, ultrasonic sensor | Ultrasonic sensor, rear centre left |
12 | E | Signal, ultrasonic sensor | Ultrasonic sensor, rear centre right |
13 | E | Signal, ultrasonic sensor | Ultrasonic sensor, rear centre left |
14 | E | Signal, ultrasonic sensor | Ultrasonic sensor, rear right |
15 | E | Signal, ultrasonic sensor | Ultrasonic sensor, rear left |
16 | Not used | ||
17 | Not used | ||
18 | Not used |
1 | M | Ground, ultrasonic sensor | Ultrasonic sensor, front right |
2 | M | Ground, ultrasonic sensor | Ultrasonic sensor, front left |
3 | Not used | ||
4 | Not used | ||
5 | A | Supply, ultrasonic sensor | Ultrasonic sensor, front centre right |
6 | A | Supply, ultrasonic sensor | Ultrasonic sensor, front centre left |
7 | A | Supply, ultrasonic sensor | Ultrasonic sensor, front right |
8 | A | Supply, ultrasonic sensor | Ultrasonic sensor, front left |
9 | Not used | ||
10 | M | Ground, ultrasonic sensor | Ultrasonic sensor, front centre right |
11 | M | Ground, ultrasonic sensor | Ultrasonic sensor, front centre left |
12 | E | Signal, ultrasonic sensor | Ultrasonic sensor, front centre right |
13 | E | Signal, ultrasonic sensor | Ultrasonic sensor, front centre left |
14 | E | Signal, ultrasonic sensor | Ultrasonic sensor, front right |
15 | E | Signal, ultrasonic sensor | Ultrasonic sensor, front left |
16 | Not used | ||
17 | Not used | ||
18 | Not used |
