1 - 2 of 2 Posts
What is this strange exhaust rattle and how do I fix it? I believe it has to do with the exhaust butterfly valve, you can see it in the exhaust hole right? Much help would be appreciated.
'17 X1 - Rooster Cruisin'
If you're sure that this rattle isn't caused by a loose baffle within the muffler or a problem with one of the exhaust pipe hangers, it's a simple mater to remove a small spring clip (between the exhaust actuator and exhaust pipe flapper) and hold this flapper in the open position by passing a stiff piece of wire thru the exposed flapper shaft slot and securing it to the exhaust actuator mounting bracket.
1 - 2 of 2 Posts
