It might be a faulty door contact switch. You can read out what caused alarm activation and condition when alarm was activated using ISTA. Not sure about you tool
Thank you, would it be the door handle for keyless entry or it can be the main door harness plug?It might be a faulty door contact switch. You can read out what caused alarm activation and condition when alarm was activated using ISTA. Not sure about you tool
Oh wow I had no idea, ok I’ll try changing and I’ll come back for updateThe latch is what makes the circuit for the alarm and the car going to sleep , not the handle .
It's the part highlighted in the link below. Make sure you confirm the part number as you need one for soft close doors, the same part is used on the F10 5-series which may not have soft close.Oh wow I had no idea, ok I’ll try changing and I’ll come back for update
Got it, that makes a lot of sense!I actually work at an auto recycling yard, so it doesn’t cost me anything to try out different parts other than my time, and we happen to have a few parts cars just like mine. So I’ll change it over the weekend and see how it goes.
