1 - 8 of 8 Posts
· Registered
Hi guys,
I've got an F10 2013 M-Sport (EU/UK) BMW and trying to locate VSU180 also known as Dynamic Voltage Converter - part number 61429251984.
Already tried checking in the luggage compartment / right side of the boot - see pictures.
I also checked the other side - left, where I managed to locate combox module.
Tried to look for the diagrams - unsuccessful. But managed to find the picture of the plastic container it goes into - see pictures.
At this point, I am running out of ideas on where to look further.
Please help,
Thanks.
Hood Motor vehicle Automotive tire Machine Auto part
Hood Automotive tire Fender Gas Automotive exterior
Motor vehicle Hood Automotive battery Trunk Automotive exterior
Vehicle Motor vehicle Hood Automotive exterior Automotive tire
Product Font Automotive exterior Auto part Automotive tire
Rectangle Font Event Art Illustration
· Registered
Seems like it is near the battery. Take a look at the removal/installation instructions:
61 42 050Removing and installing (replacing) voltage transformer
Open floor panel of luggage compartment.
Lift storage tray of luggage compartment floor (1) in direction of arrow.
Loosen nut (1).
Tightening torque 61 21 1AZ.
Important!
Do not under any circumstances use force to pull off negative terminal.
Detach battery negative lead with IBS towards top, lay to one side and secure.
Unfasten plug connection (1) and disconnect.
Unlock retaining lugs (2) on holder (3).
Pull voltage transformer (4) out of holder (3).
Installation note:
Make sure plug connection (1) is correctly seated.
Make sure voltage transformer (4) is correctly seated in holder (3).
· Registered
Discussion Starter · #3 ·
I haven't noticed it there either when I lifted the floor panel (will post a picture tomorrow). All I had under it was a battery and that's about it - see picture (not mine, but looks like that).
Hood Trunk Audio equipment Gas Computer keyboard
· Registered
Discussion Starter · #8 ·
@Ron26 Mine 100% is not in the boot. If you had a look in the boot under the floor or behind side panels and it's not there, my suggestion would be to look behind the glove box. I have had a glance there, and I believe that is where it resides. I haven't fully dug in there yet, but I am pretty sure it should be there. That's where I spotted the central gateway module and not far off from it was a block that reminded me of the voltage control module.
1 - 8 of 8 Posts
