1 - 3 of 3 Posts
Hello Bimmerfest,
I have a problem with my new F11 10/2010!
I have run a test by Ista D and the fault list is - 8011E5 Auxiliary Heating: Temperature sensor faulty
I have deleted the fault list and unlocked the Independent heater. After that i run a test on the heater by the tester Ista D. After that i go to the menu in the CIC and activate the heater and set the time. After er few second, my Heating system starts but after a short time, it’s turn off again.
I make a test with ista, and it cames with the Temperature sensor faulty..
Where did i find the sensor and changed it, so my Heating system could work fine??
Locking forward to hear from you.
Joonaz
Nuclear engineer
Your glow plug control module is in trouble too, and that can cause expensive problems.
1 - 3 of 3 Posts
