1 - 6 of 6 Posts
Hi guys I have a 2013 f31 msport automatic. In 1st, 2nd and 3rd gear I have a knocking sound coming from under the car, also when I accelerate hard the knocking sound is there. Any one experience this before if so any suggestions on what it could be. Thanks
How fast is the knocking. Does it change in speed or loudness as you press on the gas.
Could be a loose exhaust system bracket allowing it to bang against the under -body as the engine shifts position.
Discussion Starter · #4 ·
Hi, It doesn't change or get any louder. Just after the car changes gear in 1st 2nd and 3rd it knocks about 3 times and then when I accelerate hard it knocks 3 times
I had that and it turned out to be the parking brake cable was loose. Shop fixed it in ten minutes.
I got charged $800 for that repair. They said they had to take the fuel tank off and a heat shield. It was a $50 bracket that broke. Yours must have just been loose.
1 - 6 of 6 Posts
