1 - 13 of 13 Posts
Doin Work
I finally gave in and ordered 8000k HID lights for my BMW X3. I ordered to do both my lows and fogs...and also decided to mount a led daytime running strip....i also included some pics of entering the dust cover correctly!! Came out awesome...very clean and bright! I have helped a few people around town during these conversions at my shop Ultra Audioworks...and once you go HID you never can go back..lol
BMW Enthusiast!
They look pretty bright! Self-leveling I hope!
Don't blind anyone!
I was lookin to do the same thing. Did you already have the factory xenon? If so, did you use d2s bulbs?
Few of my friends got a kit from xenonvisions.com but I need to verify the bulb size before buying.
Doin Work
Discussion Starter · #4 ·
i did not have factory xenon lighting. I had halogen. I used an H7 conversion kit made by a company called X5. Good luck!
Don't blind anyone!
The problem with these kits is that the resulting light pattern is all over the place (and mostly in eyes of on-coming drivers). Halogen headlight assembly is simply not made for xenon bulbs and cannot concentrate the light well (without the projector lens).
IMHO, this type of conversion should be illegal.
Doin Work
Discussion Starter · #6 ·
lol
The picture shows both my fog lights and low beams.....the low beams by themselves, which how i usually drive is no brighter than the next guy. When the fogs are on during FOG it works very well...if used for the wrong reasons, i agree, but if used properly they are perfect.
Here is a lot of lighting info
http://www.danielsternlighting.com/home.html
You need to make sure you have set up an adjustment system on a flat system, measured per the specs. You also need to get someone to drive towards you on the open road for a good assessment of your effect on oncoming drivers. Are you sure the 8000k does the trick on backroads?
is your kit just plug and play? i had a name brand kit installed be4 and it was flickering so i took it out but it worked on my benz...
Doin Work
Discussion Starter · #9 ·
plug and play
Yes it is a plug and play kit that was fairly simple to install. I bought the x5 for my low beams and a GP thunder Prro kit for my fogs. The initial reasoning on ordering the two different brands was to compare the quality vs. The cost. GP is about 50 percent cheaper....so I would have carryed them in my store....unfortunantly the GP can't hang with the X5 lights...yes a small flicker in the drivers side and they are just not as clean looking....otherwise the lows are great...plug and play kit with awesome results....
The flicker can be fixed if an inline relay is used. basically you use your current headlight wiring for a signal to operate the relay. The relay has a heaver gauge wire coming from a 12V source under the hood. This will supply enough power to the ballasts to keep the flicker from happening.
I have factory Xenons and dont suggest the aftermarket kits because they do blind on coming traffic. BUT I do use them for off-road use on my ATV/Bikes etc. I do think that putting them in the fog lights of the BMW is a good idea. I dont think this would blind on coming traffic but would need to test this before I would install permanently.
ddmtuning.com has good quality kits for a good price with lifetime warranties on their bulbs and ballasts. I would NOT go more than the 35W kit because I have had issues with heat on the 55W kits. Also, I think that the 6k is the clearest and closest color to the factory. Somewhere between 6k-8k will be close.
HID headlight removal
i have searched how to replace the HID headlight on our 2008 X3 with HID Xenon bulb and can not find how to remove it. Could someone please help.
Thanks.
Sigh, another blinding, light scattering, purple POS headlight mod.
and yet they all claim it's "not that bad". from the driver's seat of their SUV, no less.
1 - 13 of 13 Posts
