Where was the coolant leaking from?
Have you had the error codes scanned to see why the SES light is on?
Side note, you can bleed with the vacuum method.
Open the filler cap and loosen (don't remove) the little bleeder screw next to it.
Fill with coolant to the top and close the screw when it stops bubbling. Put the reservior cap back on.
Turn the car on without starting the engine
Set the heat to max with the fan speed on min
Hold down the accelerator pedal to the floor for 10 full seconds. You should hear the water pump kick on, it's quiet though. Release the pedal.
Wait 10-15minutes until the pump stops.
Check the coolant level and top off as needed.
