Hi all,
Having some blue smoke and acceleration hesitation problems with my 550i N62TU. I expect the valve stem seals but am not 100% sure. I did some extensive diagnosis but need your help with this. Maybe things are interrelated or I have serveral issues. This is what I have done so far:
--- Vehicle ---
BMW E60 550i Euro
Model NW51
Engine N62TU
Gearbox ZF6HP26
Mileage: 175000km / 110000mls
--- Software state ---
GKE195 Gearbox ZUSB = 7592144 (latest?)
EK9286 DME ZUSB = 7593395
--- Symptoms ---
hesitation on low acceleration (1000-2000 rpm)
blue smoke when revving engine after 30+ seconds of idling with warm engine
oil in intake manifold
there are coming noticeably blow by gasses out of the valve covers when the CVV hoses are removed (as to be expected I guess)
sound (engine I guess) changes a bit after a long drive (2 hours+). Only noticeable when driving slow (<30 km/h). Vanos?
low engine torque at low RPM's (550-3000), but maybe that is just my perception
engine idling quite rough; cylinder 6 roughness value between 2.00 and 3.10
revving engine from idling not very smooth (also some minor hesitation)
drive train juddering during very low acceleration when the engine is cold (not sure if this is relevant)
slight drive train vibration during acceleration and coasting around 100-120 km/h
several small engine oil and coolant leaks
old coolant looks dark/greyish
no fault codes
-- Relevant checks/repairs ---
new crankcase ventilation valves (hoses are all clean, except some oil)
no vacuum leaks found with smoke test (exhaust not tested)
both engine oil dip stick tube and filler cap have suction
catalytic converters not clogged
fuel pressure during idling: 3.2 bar (nominal value is 3.5 bar)
compression on all cylinders ok
no DISA valve/sleeve movement when cycling ignition (according to the BMW documentation they should move. Can anyone confirm?)
intake manifold under pressure around 50 mbar (as it should be)
fuel trim see picture (+0.5 for additive is this percentage??? of ms?)
fuel system cleaner added (no influence noticed)
driving under high load (caravan in mountains) for two tanks (Shell V-power 100) also no influence noticed
new air intake filter
new engine oil+filter; Castrol Edge Titanium 0W-30 (BMW LL-04)
new spark plugs
coils swapped around cylinders
coolant changed
new battery
--- Vehicle ---
BMW E60 550i Euro
Model NW51
Engine N62TU
Gearbox ZF6HP26
--- Symptoms ---
no fault codes
new spark plugs
coolant changed
new battery
