BMW NBT Evo - Problème de codage ! SVP AIDEZ-MOI PAS DE SIGNAL
11K views 2 replies 3 participants last post by  Florissilfhout
#1 ·
Bonjour, j'ai un problème avec
BMW M4 navigation NBT EVO, après le codage EsysPlus, l'écran affiche le message "pas de signal", l'unité n'a plus de position CAFD. J'ai essayé de "détecter CAFD SWE", détecte correctement mais se termine par une erreur :
Recherche de Caf
Tal est généré
Démarrage du traitement
TAL execution started.
VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197]
ExecutionID=2016/12/09-16:25:19.158
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[HU_NBT2 - 63] prepareECUforCoding started
[HU_NBT2 - 63] prepareECUforCoding finished
[HU_NBT2 - 63] authenticateECUforCoding started
[HU_NBT2 - 63] authenticateECUforCoding finished
[HU_NBT2 - 63 - cafd_00001ef6-006_018_016] Transaction type: cdDeploy; Message: TA started
MCDDiagService<id=62649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : requestOutOfRange, link=HU_NBT2_63_ETHERNET>
[HU_NBT2 - 63 - cafd_00001ef6-006_018_016] Transaction type: cdDeploy; Message: TA finished
[HU_NBT2 - 63] There was an error during TAL execution, please check the log files.
[HU_NBT2 - 63] - [Exception - HU_NBT2 - 63] job failed with negative response error:
code: service returned global negative response
description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; ECU: HU_NBT2_63_ETHERNET
severity: ERROR
[HU_NBT2 - 63] finalizeECUCoding started
[HU_NBT2 - 63] finalizeECUCoding finished
[] There was an error, please check the log files.
[] - [Exception - HU_NBT2 - 63] job failed with negative response error:
severity: ERROR
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "24s". [C206]
Traitement terminé
J'ai essayé plus tard le codage NBT par ISTAP mais "FinishedWithError" Rheingold affiche des erreurs :
026308 - HU-H Aucune donnée de codage actuelle stockée
02630A - HU-H Données de codage non activées
B7F87F - Défaut de codage HU-H
B7F880 - Défaut de codage HU-H
B7F8C3 - Connexion, unité principale vers CID
E14600 - TCB : Ethernet : Terminaison de communication inattendue.
Aidez-moi s'il vous plaît, merci
#2 · (Edited)
Si EVO est installé en usine, alors :
1. Détecter CAFD
2. Faites un clic droit sur NBT2, puis CODE. À ce stade, il redémarrera
3. Appliquez votre codage FDL personnalisé à l'aide d'ESys à la place
4. Si votre FDL est incorrect et non applicable à votre voiture, ou si votre numéro VIN de fichier FA ne correspond pas à votre VIN NBT2 stocké, alors il échouera à nouveau de la même manière.
