1 - 4 of 4 Posts
My Passenger door stopped opening from the inside and out. I tried replacing the electric window module and it still did not work, I have since found that for some reason if I open the glove box and close it then the door will operate normally. After a while it reverts to being locked again and I repeat the opening and closing of the glove box and its ok again. Really not sure whats going on here... anybody have an idea?
Nuclear engineer
Wow! The door latching mechanism quits working so he changes the window ***8216;module***8217; and now can***8217;t figure why cycling the glove box affects the door latch? Wheew, neither can I. Good LUCK.
Discussion Starter #3
I changed the window module because it has the door mechanism wired up to it and I was told it was linked and would fix it, as it did on somebody elses car on a similar forum... Thanks for your help, I expect you are a bundle of laughs normally... just not today.
Nuclear engineer
1 - 4 of 4 Posts
